Dean in Eureka, CA wrote:Question about the first coat:
Was the back side of your gunnel sealed also, or just the side showing in the pic? (IE... Does the surface that is in contact with the work bench have sealer on it also?)
Yes, the entire gunnel was coated...I was always perplexed as to why, after you fiberglassed the outside of a canoe with no bubble problems what-so-ever, that you had to constantly fight bubbles on the first coat on the inside...even with a precoat.
I still think that the best prevention for outgassing has always been the Number One Rule with epoxy...warm up the wood and epoxy to the appropriate application temp, then let the temps drop as you do the application.
Gee, I sure confused everyone with my post...I'm so sorry if I mixed up a topic about sealing wood on a Tear and maybe a finer point on glassing. That certainly wasn't my intention and please accept my apologies...Juneaudave
