I've been reading the posts about glue seeping out on seams when clamped and then having to be sanded or scraped off, and that sometimes dents result. Would it be a good idea if you are doing a woody to put a coat of sealant on before you glue up a seam or would some sealant running down into the areas to be glued cause problems with the glue joint?
Also, if a person planned to coat an exterior surface with marine duck canvas, what type of surface preparation should be considered before glueing the fabric onto the plywood?
Thanks.
Kris
p.s. Hope I didn't miss info about this elsewhere.
