I got the overall priciple down on both. Does one have an advantage over the other? Are they structurally about the same strength I am not worried about the weight difference (should be minimal I am thinking) using the same materials
Woody
I have 2 vacuum pumps 1 is an El Cheapo Harbor Freight venturi pump. The other one is a Robinair that I use to evacuate airconditioning systems. I will try the cheap one first to see how it works.
