Is this possible/ been done?
Postby Maniac H3 » Mon Aug 28, 2006 8:17 am
I have been reading alot about sealants on this site... Almost all agree in some kind of penetrating epoxy.
Doing research I found a key element in most "Aliphatic Urethane"
My thought is to use a garage floor sealant with Aliphatic Urethane.
This product states that it can be used on wood.
http://www.floorsthatlast.com/index.htm
If I find a product like this do you think it might work???????
Was planning a thin coat to penetrate first, then a thick coat to finish.
Looking for any help....... with the hurricane coming... I will need to keep busy.
Maniac
[/url]
Maniac H3
Images: 43
Postby Miriam C. » Mon Aug 28, 2006 10:07 am
Maniac,
There is another tear that is coated with Garage floor epoxy. This product
recommend you topcoat EpoArmor®
. Check you pricing. You may find Marine epoxy less expensive even though you top coat.
Good Luck
Postby jimqpublic » Mon Aug 28, 2006 10:33 am
We put a two-component (resin and hardner) epoxy on our garage floor several years ago. One thing I noticed in shopping was that most of the "epoxy" paints sold to the general public are one-component. In other words they have cured epoxy solids in a solvent carrier. Although you get abrasion resistance of the epoxy solids, you don't get the real benefit of a monolithic coating like you do with a two-component coating.
The two-component urethane topcoat sounds interesting though.
Jim
2002 Chalet Arrowhead but always wanted a Teardrop
2 kids and a Dear Wife
http://community.webshots.com/user/jimqpublic
jimqpublic
epoxy finish
Postby jay » Mon Aug 28, 2006 6:00 pm
VERY slippery when wet!!!
jay
