Need advice for roof seams...how did/are you doing yours?
Postby kayakrguy » Sat Nov 18, 2006 12:52 pm
Friends,
Roof not on yet....spent nearly a whole morning trying to find the insulation I needed....but, I anticipate starting roof tomorrow...
I would like some advice on the ply joints in the roof. Here is what I am thinking of doing....
1) putting Fill It Epoxy filler in the seams and sanding smooth.
Do I need to do anything else by way of sealing the seams?
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Re: Need advice for roof seams...how did/are you doing yours
Postby mikeschn » Sat Nov 18, 2006 2:11 pm
kayakrguy wrote:Friends,
Jim
Jim,
I made sure my joints fell on a spar, and I glued them up good to the spar.
Then I filled in the joints with epoxy filler and sanded it smooth.
Finally I put a good coat of paint on it.
So I think you are on the right track!
Postby kayakrguy » Sat Nov 18, 2006 5:14 pm
Mike,
Thanks for the reply...
I've got the spar spacing figured out for the ply as you said. Did you screw the ply down as well as glue?
Have you tried to do a seamless roof?
Steve Frederick's build shows doing that. I don't have a table saw or I might be tempted to do that.
Jim
Edmund Burke
kayakrguy
Images: 195
Postby mikeschn » Sat Nov 18, 2006 5:18 pm
I used big headed nails in the Baja Benroy, which I also sunk and filled with epoxy filler.
On the Escape Hatch I countersunk the screw holes and filled those with epoxy filler.
The plans for the Generic Benroy call for a seamless roof, like the one Steve Did on the Lil Diner. But it's not truely seamless. Steve still had to fill it in with epoxy and then finish it with spar urethane.
So plan on using something, irregardless of your construction technique.
Postby kayakrguy » Sun Nov 19, 2006 8:38 am
Mike,
Thanks again! I think the message is that glue and screwing is the way to go to be sure the roof stays on--seams or not....got it...
Jim
Edmund Burke
kayakrguy
Images: 195
Postby surveytech » Sun Nov 19, 2006 9:09 am
If you can make the seams fall on a flat section it will make it easier to make them disappear.
surveytech
Images: 6
Postby kayakrguy » Tue Nov 28, 2006 5:52 pm
STech,
Thanks for that advice...we are trying to do that. I think we have the spacing figured out so that will be possible.
Jim
Edmund Burke
kayakrguy
Images: 195
Postby War Eagle » Wed Nov 29, 2006 9:11 am
Kayak excuse me for jumping in but I have a similar question related to the roof. How do you join/ seal where the roof and walls meet? I have not decided between a metal or wood roof, can someone address each application?
Thanks
War Eagle
Images: 6
and following on
Postby Creamcracker » Wed Nov 29, 2006 11:05 am
if you have joined panels and then infilled with the epoxy filler does this mean that you cannot do a clear urethane varnish/finish over the wood? Do you have to paint? I guess the same question would be true if there was a seamless roof but with epoxy filling in the screw holes etc?
Creamcracker
Teardrop Graduate
Images: 142
Postby Ira » Wed Nov 29, 2006 11:22 am
War Eagle wrote:Kayak excuse me for jumping in but I have a similar question related to the roof. How do you join/ seal where the roof and walls meet? I have not decided between a metal or wood roof, can someone address each application?
Thanks
Eagle, people use different stuff, but I used 3m's 5200 marine "adhesive" which comes in a small tube. (HD carries it.) I simply filled the gap/seam and spread it a little with a screwdriver.
Anything you use there is going to be hidden by some kind of molding anyway, so it doesn't have to look real pretty. I used the 5200 because it's meant for wet conditions, it stays flexible so it doesn't dry out and crack, and also since it's flexible, it's just right for the kind of stresses that those corners are going to be exposed to when turning/towing.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Steve Frederick » Wed Nov 29, 2006 5:29 pm
Jim
I used a cordless circ-saw to cut the width, a router to "join" the sections, 'glassed the seams while on the table, then applied to the roof...No table saw involved! In fact, I only use a table saw to mill cabinet door parts, and rip spars!! Otherwise, no bench tools!
Joining the sections eliminates the requirement to hit a spar, and the joint won't open on the curves!
You did read the manual, didn't you??? ;) ;) :R
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
