BILLYL wrote:Tony-
I think I have it. So the metal plate and the clamps are really holding it in place.
Thanks
BILL
The metal plate rides on the back side of the panel holding it in place. When the clamps are tightened, it will end up between the spar and the backside of the panel. The 2x4 butts against the top edge of the panel and pushes it into place as the clamps are tightened. The 3/4" furring strip is used to bottom against the spar and set depth to seat the panel. The aluminum bar keeps it all from twisting.
