Can someone tell me about this roll and tip method of painting,I missed that thead somewhere and cant find it in search? Thanks
Arne,
The trailer builders we know of have just rolled Uniflex on the Uniflex
and left the surface stippled. It can be applied with a brush, or
brushed out, although as with most heavy coatings it would have to be
cut a little, in the case of Uniflex with xylene. If cut with xylene,
then generally three coats are applied to get the proper film thickness.
Your plan using the Interlux paint will work just fine, although surface
durability will not be as long as with the Uniflex. I would use a
hi-build primer over the CPES'd surface, not for protection but to help
you achieve that very smooth final surface for the paint. Boat owners
will often apply the primer, sand smooth, apply the primer again and
sand smooth, and then apply several coats of the high-gloss paint. It
should work just fine.
Doc
The Rot Doctor
http://www.rotdoctor.com
E-mail: [email protected]
CLEAR PENETRATING EPOXY SEALER™ • CURE TIME CHART
Pot Life At Temperature Warm Weather Formula Cold Weather Formula
86°F/30°C 4 hours Not Recommended
68°F/20°C 8 hours 2 hours
50°F/10°C 16 hours 4 hours
32°F/0°C Not Recommended 8 hours
Full Cure Time Required
86°F/30°C 2 days Not Recommended
68°F/20°C 4 days 2 days
50°F/10°C 8 days 2 days
32°F/0°C Not Recommended 4 days
WARNING: This product is inherently unsafe. It cannot be made safe. That's why it works so well. It can be applied in the open air safely (although we always use and recommend latex gloves) but if used indoors a respirator capable of filtering organic solvent fumes is essential.
Juneaudave wrote:....wet the surface of the concrete to keep dust down and kill static.
...anyone else have suggestions or something different??
martha24 wrote:Here's a good place with lots of info about roll and tip method of painting:
http://www.asolidfoundation.com/dd_shell_2.shtml
Joanne of Desert Dawg has a really great website and has lots of great pictures.
I've been looking at using Interlux over the CPES, as I really liked the sound of the Interlux primer, in being able to sand it really smooth.
Martha
