Anybody Spraying Poly??
Postby Steve Frederick » Tue Mar 13, 2007 11:07 am
Joanne wrote:
On everything that I sprayed I used three coats, sanding between them. As you might guess, the first coat is more of a sealer. Sanding after the first coat really gets things smoothed out. I was really surprised how the cheap Home Depot birch ply came alive after a couple of coats of the poly.
Joanne
Hey, Thanks for the link!
You did a great job with that spray-gun, by the way! :applause: :applause:
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby rbeemer » Tue Mar 13, 2007 12:05 pm
Steve,
Here is a link for flattening shellac should be able to find it a woodworking supply shop
http://www.shellac.net/ShellacFlatting.html
Rick
If ducks had scales, would fish quack?
rbeemer
Postby bdosborn » Mon Mar 19, 2007 10:08 pm
Steve,
Almost forgot, here's a link on setting up your HVLP gun
Linky
Images: 806
Postby Steve Frederick » Tue Mar 20, 2007 6:35 am
bdosborn wrote:Steve,
Linky
Thanks Bruce, and everyone!
As you can see, I need to git-r-done, as Auntie M says!! :lol:
Next question..Top to bottom, bottom to top?
Corners first, second??
I'm gonna run outta time/excuses, so..as Miriam says!... :?
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
