cutting aluminum
cutting aluminum
Postby Roddy Riggs » Tue Mar 20, 2007 8:58 pm
Help somebody: I bought 040 aluminum for my tear, because it was the width I needed and the price was right. Now, I am about to put on the sides and here is the problem. This stuff is very hard to cut. If I glue it onto the side how do you guys trim it off flush? If I cut it to fit first, I still have to leave it a little large to trim down flush. Some have recommended using a router with a speed control. That didn't work for me. When I used it under full speed, I smoked the bit!..I was thinking of using an air nibbler which leaves about 3/16" above the top and then taking a die grinder and try to smooth it out. What do you think. Any suggestions welcome. thanks, Rod
I've been to three county fairs and a goat roping, but I ain't never seen anything like this!
Roddy Riggs
Postby Geron » Tue Mar 20, 2007 10:01 pm
Hey Roddy,
I didn't use a "nibbler" I used air shears. With the Air Shears the bottom blade slides right along the edge of the top and cuts the side virtually even with the top. No need to file or sand very much.
My bad, It was shears, not nibblers I used
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby alaska teardrop » Tue Mar 20, 2007 10:24 pm
Roddy - Air shears as Geron suggested. If you don't have air, there are electric shears that work fine on .040". Suggestion: Lay up the side panel & clamp in place. Scribe the backside by following the outline of your profile. Remove & cut on a clean surface. Shears tend to gouge the aluminum. Cutting on the backside prevents damage to the outside surface.
    Fred
    :peace:
alaska teardrop
Postby madjack » Wed Mar 21, 2007 12:05 am
...use air shears...mark it out and cut...you can use the side as a template/guide for the shears or mark the al and then freehand it...we used our templates as a guide for the shear.....
madjack 8)
Postby Joseph » Wed Mar 21, 2007 5:02 am
I used a hacksaw blade on my jigsaw when cutting my .040. Had to file it a bit, but otherwise no problem.
Joseph
Joseph
Teardrop Pirate
Postby SteveH » Wed Mar 21, 2007 6:58 am
I used a router to cut the aluminum after it was glued to the sides, and a hacksaw blade in a jigsaw to cut it to length. I would do neither again because of the metal cuttings getting under the saw and router scratching the aluminum. I would try the air shears.
SteveH
SteveH
Images: 42
