by Keith B » Tue Mar 20, 2007 4:01 pm
These are the screws I've used...trust me...they are good and they are strong. They have two bits on them prior to the threads...one is for drilling through the wood to create a pilot hole...as soon as they hit steel, two little tits break off and the second driller is exposed to go through and thread into the steel and once that happens they SINK. The key is to not put them in a 2000RPM or you'll burn the end and it wont "drill", and they do require a little downward pressure (provided by your very own arms). Personally, I have NEVER broken a new one in half..only old ones that I've "tried" to remove... and I've plowed 'em through 1/4" steel. Those are all that holds the floor down on all our wheat trucks, which each hold about 22,000 pounds...but, be prepared, as they're going to be about $1 a piece. I've also used them to screw 2x4s to steel post for fencing...you can find them at ACE if you don't have a trailer shop and you should have 3/4-1" of threads going through and past your steal. I recommend getting them prime coated or hit the bottoms with some spray paint after you've installed.
Winged Self-Drilling Screws for Decking Applications (Mezzanine Floors)
The screws are designed to drill a clearance hole in the timber and then self drill and tap into the steel. The wings on the drill point ream out the clearance hole in the timber but break off once they hit the steel, allowing the screw to drill the exact hole diameter for the tapping operation.http://www.aspltd.co.uk/floor-screws.php
Keith B on Tue Mar 20, 2007 9:02 pm, edited 1 time in total.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
