shamrock wrote: Is there a big diffrence between 1/2 and 3/4 plywood for floors?
Dale M. wrote:shamrock wrote: Is there a big diffrence between 1/2 and 3/4 plywood for floors?
About 1/4 inch....
Dale
shamrock wrote:Thanks Asian, thats what I was looking for . Now, All I can get is A/C plywood , Is there a best way to lay this, as in the "A" side -Inside for the floor or Outside twords the ground or vice versa?
Keith B wrote:5'x10' x1/2" or 3/4" only is a very standard size in commercial cabinet and counter building...we use it all the time; HOWEVER, you need to go to a "lumber yard" not a home store...and drag your wallet along, as it's going to be close to $80-$100 a sheet pending on finish....another option for you...pingpong board is 5x9, but again, you have to go to a lumber yard.... My floor is made out of 2 pieces of 4x8 1/2" BC (TD is 5' wide, so I had 3' of scrap) w/ adequate framing... far cheaper.
Keith B wrote:Miriam...It's called Schutte Lumber in Kansas City, Mo near 635 and I35... 3/4 AC 5x9 is $90, 3/4 AC 4x10 is $70 but they're out of the 4x10 for about 10 days.
