T-Molding Help
T-Molding Help
Postby Sierrajack » Sun Apr 29, 2007 7:37 am
My doors look almost exactly like Airspeed's. The problem I'm having is when I mount the t-molding on the doors, it drags and hangs up on the front edge of the opening when I try to shut the door. Where am I going wrong? Would it solve the problem if I put the t-molding on the inside of the opening instead of on the door? I'm 90% complete on the build and this is holding me up bad....
Sierrajack
Images: 41
Postby bledsoe3 » Sun Apr 29, 2007 12:06 pm
Sounds like your door is a tad to big.
bledsoe3
Images: 112
Postby Miriam C. » Sun Apr 29, 2007 12:18 pm
Try digging out the sander and remove the slightest bit at a time. Time consuming but you will be sure not to get too much. Check your door edge and be sure your cut is not beveled. (or bevel it :twisted: )
Postby diverguy » Sun Apr 29, 2007 1:15 pm
i used a big rubber mallet. then i fgured out my screws were not countersunk. LOL.
diverguy
Images: 192
Postby toypusher » Sun Apr 29, 2007 2:11 pm
Pictures, please? I don't fully understand the problem. Maybe a couple of pics would help..
toypusher
Images: 324
