Froad Toad
Froad Toad
Postby Steve F » Mon Apr 30, 2007 8:05 am
After looking at some designs and my Jeep Cherokee I decided that a square shape would suit what I want and to keep costs down I designed this around the size sheets I could get easily. It's 2.7m long, 1.2m high and 1.5m wide (internally) (Thats about 8.8' by the usual 4' high and 5' wide) and runs 31" tyres.
I have Rik Keller to thank for the inspiration hence the name Froad Toad (Offroad Toad). I still have a bit to do (like interior cabinets etc) but the basics are there and I can start building soon :)
And with the Cherokee, mine is about 7" higher off the ground than this one so I'm hoping roof heights will be about the same with the TD possibly a little lower than the Jeep.
Cheers
Steve F
Images: 25
Postby Dale M. » Mon Apr 30, 2007 10:12 am
Have you viewed this site...
http://www.outbackteardrop.com/
This off road TD may help you with some design feature... Mine is going to be pretty close to this design once I can locate a shop to build it in....
Dale
Dale M.
Images: 18
Postby Keith B » Mon Apr 30, 2007 10:25 am
Do you really need mud and snow tires on a TD :lol: I like the design...
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby Steve F » Mon Apr 30, 2007 4:46 pm
Dale M. wrote:Have you viewed this site...
Dale
I do like the rollbars on those. I'll probably incorporate Jerry can holders behind the rear wheels and a few other remote touring type modifications and grab some ideas from them.
Keith B wrote:Do you really need mud and snow tires on a TD :lol: I like the design...
Probably not ;) They were the nly 31" tyres I could find already done on Sketchup and since this was my first go I ttok the easy way out :)
Cheers
Steve F
Images: 25
Postby GPW » Sun May 06, 2007 4:06 pm
With the utter simplicity of the body, why not just square off the rear end and use conventional doors , instead of a hatch ... you could even let the sides extend past the squared off part (as shown) just for aesthetics...Room above the rear doors for a small awning , and you don't need to spend a fortune on hatch hinges... :roll: Just crumbs for thought...
