Where Can I find One Of These
Postby Classic Finn » Sun Jun 10, 2007 4:56 pm
Where could I order one of these from and how is it installed? Does anyone have one on their tear .. and if so would you have a photo or 2 of its installation?
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby s4son » Sun Jun 10, 2007 5:20 pm
I got one like that from Austin Hardware. I can't really tell you how I installed it. You can figure it out after you look at it for a few minutes (if I can, anybody can).
Scott F.
Are we there yet?
s4son
Images: 180
Postby Classic Finn » Sun Jun 10, 2007 5:22 pm
s4son wrote:I got one like that from Austin Hardware. I can't really tell you how I installed it. You can figure it out after you look at it for a few minutes (if I can, anybody can).
Scott F.
Hi Scott
Do you have a photo of it installed?
Classic Finn :thumbsup:
Classic Finn
Images: 146
Postby s4son » Sun Jun 10, 2007 5:23 pm
Let me look, if not I can get a couple.
Are we there yet?
s4son
Images: 180
Postby goldcoop » Sun Jun 10, 2007 5:25 pm
Heikki-
http://austinhardware.com/product.asp?d ... %5Fid=1129
I used one of these.
To install:
Bore center hole towards the bottom edge of the hatch.
Attach latch to backside with the rods (which you will cut to protrude out about 13 mm each side).
I used LIPSTICK on the ends of the rods, close hatch, turn latch (spreading the rods out) the lipstick will leave its mark on the TD side panels!
Simply drill a hole (slightly larger than the rod diameter) about 15mm deep at these marks.
I don't have a photo of this, but we'll see what I can do...
Hope this helps.
Cheers,
Coop
goldcoop
Images: 32
Postby s4son » Sun Jun 10, 2007 5:47 pm
Like Coop said.
I framed the hatch with two parallel cross members with blocks where the handle would be attached.
After test fitting I skinned the inside. I wanted this on the outside in case I neede to get to it.
I used ink on the end of the rods to find the location. After drilling through insert the rods. The trick is to get them flush when the latch is open but sticking through enough to latch when closed.
Next drill the coorsponding hole in the side for the rod to latch into.
After skinning the outside of the hatch install the handle.
Hope this helps. Please don't laugh at my pictures, I am neither a carpenter of a sheet metal worker. :)
Scott F.
Are we there yet?
s4son
Images: 180
Postby Classic Finn » Sun Jun 10, 2007 5:47 pm
goldcoop wrote:Heikki-
To install:
Hope this helps.
Cheers,
Coop
Good Morning Coop
I like it .. you used mm for the measure.. 8) 8)
Im checking my Marine Catalog here if I can find one of them that may be similar.. :thinking:
It looks like it may be easy enough to install.. ;) :D Now if I can only find one around this part of the world :lol: :lol:
regards
Classic Finn ;)
Classic Finn
Images: 146
Postby Classic Finn » Sun Jun 10, 2007 5:50 pm
s4son wrote:Like Coop said.
Scott F.
Scott thank you for the photos indeed.. dont worry I wont laugh nor judge another mans woik..I am neither a carpenter nor a locksmith...but darn I try ... :lol: :lol: :lol: Yupper these photos help me to get a good idea how its done.. :thumbsup:
Thanks Again
Classic Finn
Classic Finn
Images: 146
