48Rob wrote:Good morning,
The window is set in the opening from the outside.
The ring is set in the opening on the inside.
The screws serve to pull the two halves together and thus "clamp" the widow tight against the side of the trailer.
Rob
madjack wrote:...just don't forget to seal the outside or you will get REAL wet...if you use the clamp ring, putty tape is probably best for sealing...
