Wood seams waterproofing and frame placement
Postby Syekick » Wed Mar 23, 2005 9:04 pm
I'm considering wood, not aluminum for the exterior.
1. If I use a design that requires a seam across the side wall or top will a butt joint be OK with a frame member behind it for support?
2. Do I need to fill the seam with something?
3. Will I get a waterproof exterior with just epoxy (no glass) or one of the high end paints mentioned on the forum covering the seam?
_______________________________________________________
I'm not new to wood working. I can light a campfire on the first try.
<b>Fudd's First Law of Opposition: </b>
If you push something hard enough, it will fall over.
Syekick
Re: Wood seams waterproofing and frame placement
Postby Steve Frederick » Wed Mar 23, 2005 9:55 pm
Syekick wrote:I'm considering wood, not aluminum for the exterior.
If you make your joint over a framing member, it should work well.
Syekick wrote:2. Do I need to fill the seam with something?
I would fill the joint with epoxy, and cover the joint with 'glass. If you don't bond the joint some how, You'll run the risk of the joint moving, and producing a crack in the finish. You wouldn't have to do the whole panel, just any seams. You can cover with a urethane or epoxy paint...Should look great!!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby ALAN GEDDES » Wed Mar 23, 2005 10:03 pm
Your local hobby shop that sells Radio Control Airplane stuff will have the tape/cloth you need in small enough quantities. We use it for wing center sections and such. You can get some epoxy there too.
Alan
ALAN GEDDES
Images: 34
Postby Steve Frederick » Wed Mar 23, 2005 10:08 pm
ALAN GEDDES wrote:Your local hobby shop that sells Radio Control Airplane stuff will have the tape/cloth you need in small enough quantities. We use it for wing center sections and such. You can get some epoxy there too.
Poifect!! :thumbsup: Just make the joint, smooth it out, and paint it!!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby doug hodder » Wed Mar 23, 2005 10:11 pm
I agree with Steve. I've done a lot of epoxy work also. I would back up the joint with some sort of backer and I would thicken the epoxy so that it would stay in place until it cures. This would also allow you to check for good squeeze out on the epoxy, an easy check to make sure you got a good bond. If you are thinking about automotive type polyurethane paint, you will need to coat out all the wood with epoxy, at least enough so that you are happy with what will be the finish. The top coat is only as good as the prep work under it. Auto paints need to bond to something like epoxy,or in the case of a car, primer, it won't work on wood alone. Doug Hodder
Users browsing this forum: jgmahoney and 4 guests
