Im apllying the aluminum on my trailer next weekend. I was wondering if any of you had used this on your trailer.
Did you put trim around it? how did you secure it?
yes ive done a searc
thanks bob
Jeeper92 wrote:Im apllying the aluminum on my trailer next weekend. I was wondering if any of you had used this on your trailer.
thanks bob
Jeeper92 wrote:that looks great.....how are you securing it?????? GLue? I was thinking of glueing it adn then siliconing the edges. Im really struggling with how to figure out how to trim it out, do you put the plating on first then trim around it? then around the other parts of the trailer? how do you keep it flush?
Classic Finn wrote:Jeeper92 wrote:that looks great.....how are you securing it?????? GLue? I was thinking of glueing it adn then siliconing the edges. Im really struggling with how to figure out how to trim it out, do you put the plating on first then trim around it? then around the other parts of the trailer? how do you keep it flush?
Im securing it with sikaflex and then a few stainless screws... especially at the screw holes..
As you can see Im using a few clamps to hold it in place.. and its flush.
before I install it all the way especially on the top I,ll use the moulding I mentioned above.. because it slides right in and it will lock in place..and behind it I may seal it up too on top behind this moulding so water wont get in there..just to be safe..
I,ll get some photos of the moulding that is widely used for kitchen tile edging or even bathroom tile edging here in Scandinavia .
Im putting the screws about 5 inches apart... maybe others are doing it differently but this is my way as the song goes..![]()
I would cut and trial fit this first so you know it will fit ok.. especially if you have curves or sharp radius,s as I do...
I,ll get back to you with photos ... hope that helps you out a little
Regards Classic Finn
Jeeper92 wrote:any kind of sealant?
what kinda screws are they called?
Im going to be putting a 10 foot by 2 foot pieces on each side and a 6 foot by 4 foot in hte front and a 2x2 in hte rear
