Flooring question of which wood.
Postby Ron Dickey » Thu Feb 24, 2005 9:45 pm
I understand that it could be 1/2 or 3/4 plywood
but what is the difference between
exterior plywood and Reg. plywood.
At HD I found some 3/4 mapel sanded for $45.
Ron D. :?
173882......173887
Ron Dickey
Images: 787
Postby Steve Frederick » Thu Feb 24, 2005 9:53 pm
The difference is the glue used to assemble the ply's layers.
For the floor, it shouldn't make a difference, if you are covering the road side in tar, or paint etc.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby madjack » Thu Feb 24, 2005 11:05 pm
...exterior ply has a waterproof glue...I am using 5/8 ACX for my floor and sheathing it in aluminum like the top and sides
madjack 8)
plwood glues
Postby An Ol Timer » Thu Feb 24, 2005 11:31 pm
All plywood today (except maybe some cheap stuff listed as interior only) is manufactured with waterproof glue. Stop and think when was the last time that you left a piece of plywood out in the weather and it delaminated.
An Ol Timer
Postby Eric Adams » Sat Feb 26, 2005 11:50 am
I used Advantech. 50yr life and its a epoxy coated board. Easy to cut and looks/feels like it'll take a bullet. 8)
It is smooooooth also. I used it as flooring because it can take being submerged completely for long periods with no harm at all and cost $21 a 4X8 sheet of 3/4". Not a bad deal and you don't have to coat the underside of it. I bought it at a local Myers Lumber yard.
Eric Adams
Postby Ron Dickey » Thu Mar 24, 2005 2:28 pm
will pine work or should this be a hard wood?
173882......173887
Ron Dickey
Images: 787
Users browsing this forum: jgmahoney and 2 guests
