...for all...we use an 11ply cabinet grade ply for floors(1/2") and 13 ply 3/4 cabinet grade for walls...common ply...even AB grade will be 5ply and 7ply respectively(if your lucky)...the additional plys makes for a more stable product(resists warpage better)...further... we get our ply from a cabinet shop supplier and it is a Baltic Birch outer veneer with a poplar core and I have never found a void in it...this not the cheapy chi-ply stuff you get in the box stores nowadays...we also seal EVERYTHING with several coats of either a solvent based urethane or an epoxy...we consider this to be very cheap insurance for our peace of mind!!!!!!!!!!
p.s.FYI... we get this product at wholesale from our supplier...averages around 30bucks(or less) a sheet............MJ
p.s.s...TP, we don't build composite(sandwich) walls or floors...MJ
p.s.s.s. Gage, the only pingpong table material I have been able to find is made of particle board...we ship all the good stuff out Cali and up to NY...or overseas.........MJ
p.s.s.s.s....after saying all of that...use the best materials you can find/afford and a bargin is not always a bargin in the long run...as someone famous once said...the cost is forgotten as soon as the fun begins(or some such)!!!!!!!!!!!!MJ
