Cut all of the wood to the correct size & then laid them on the trailer & I
also used a bunch of 1/4" spacers between each 2 X 6.
Now they are ready to be screwed down.
Also mounted some lights on the front outside corners of the trailer.
I predrilled the wood only. And these are the 2-3/4 self drilling screws that we're used.
In this picture I capped the exposed 2 X 6's, And I placed a piece of angle iron on top of the wood, I will drill some holes through the angle iron & bolt it to the frame to hold down the wood, the reason I am doing this is so if any of the wood needs replacing in the future the angle can easily removed.
This pic shows the angle iron that was welded on the rear of the trailer to cap & secure the wood down.
The jack has been bolted on and the safety chains have been welded on.
You can also see that the bolt holes have been drilled & bolted, On the angle holding the wood down.
End piece has been painted & taillights have been mounted.
Also mounted the lights on the rear center of the trailer.
Trailer was also taken down too the DMV and registered.
It is now ready for the road.
All that needs to be done now is the tailgate.
The tailgate will most likely be done this week.
The Sin City Teardropper.
Ken F.
( www.VegasTeardrop.com )
( http://vegasteardrop.com/TD_and_Misc_Const_.html )
