water proof door joint?
Postby BaerClaw » Fri Mar 28, 2008 2:57 pm
on a td how do you make the back kitchen door joint water proof? it looks like water would go right in when it runs down the roof!
BaerClaw
Postby mikeschn » Fri Mar 28, 2008 3:21 pm
Are you talking about the galley hatch? :? Kitchen door? You need to tell me what style you are building...
Postby Dean_A » Fri Mar 28, 2008 4:00 pm
Assuming you mean the galley hatch, most folks use one of the hurricane hinges. More info here:
http://tnttt.com/viewtopic.php?t=11210
Dean_A
Images: 55
Postby Miriam C. » Fri Mar 28, 2008 4:04 pm
If you are talking the hatch top you can use a hurricane or some of the others listed in Sdtripper's index above. If you get your hurricane from Grant at Lil Bear you will get the right length. 8)
We also put insulated striping on the sides. You can get that from Grant in the right length also. :D I'm into simple. :thumbsup:
galley hatch
Postby BaerClaw » Fri Mar 28, 2008 6:07 pm
yes a galley hatch 1/4 Nelson style td. ok thanks ill look in to those.
wow i looked at the link it has ever thing! thanks for the help. i think i might use lilbear to get it.
BaerClaw
Postby mikeschn » Fri Mar 28, 2008 6:29 pm
Definitely grab a hurricane hinge from Grant, or one of those flexible hinges from McMaster Carr.
go to mcmaster.com and do a search on Harsh-Environment Plastic Piano Hinges without Holes
or get Grant's hinge here
http://www.lilbear.teardrops.net/parts.html
Postby Ralf » Fri Mar 28, 2008 8:55 pm
I just used the McMaster plastic hinge. Piece of cake, I used a strip of 1/16 inch aluminum on top of the hinge and drove screws through the 1/4 inch hatch skin into the 1 1/2 oak top hatch spar. Use a hardwood for your top hatch spar, double it or rip it wider than rest of spars. A little extra width helps the error/slop factor when you hinge your hatch. I used a doubled oak spar for my rear most cabin spar for the same reason.
Changing subject, I used exterior star drive screws 1 1/4 long for initial fastening without predrilling pilot holes. when the glue drys I either back them out and fill the hole or substitute stainless screws depending on location. A real time saver and handy if you don't have a helper. Most times the stardrive screw will hang from the bit so you can one hand it with practice.
Good luck. Remember, mistakes are only design oppertunities. Don't sweat them and keep moving forward.
Fayetteville West Virginia, at the rim of the New River Gorge National River. Whitewater, mountain biking, rock climbing. One of BUDGET MAGAZINE'S TOP TEN COOLIST SMALL TOWNS IN AMERICA. Fetured in National Geographic Adventure Magazine., Noah Adams' (NPR) book,"Follow the River". Neww River George Bridge, 876 foot tall single arch. On Bridge Day sky divers jump from the bridge and live, most of the time.
Ralf
Images: 15
