dropping the whole thing
Postby Miriam C. » Thu Apr 10, 2008 10:09 pm
Jester wrote:Sorry Miriam :oops: Did not see that you wanted to lower the whole trailer before I prattled on about those blocks!!
:lol: :lol: 8) It is alright cause you almost got me talked out of it. I really hate cutting into this thing. It's like cutting my baby. :cry:
Postby del » Thu Apr 10, 2008 10:17 pm
If it were mine I would install the original shackles, and put in the blocks, not cutting holes in that beautiful trailer. You should be able to buy those from the same place one would buy springs, longer U bolts will be required.
del
del
5000 Club
5000 Club
Images: 410
Postby starleen2 » Thu Apr 10, 2008 10:20 pm
Just a quick sketch - Is this what you are suggesting?
I would run the longer pieces longitudely to get more surface area across the trailer frame cross pieces. of course the top facing would cover over the wheel cutouts and provide a level floor. Should work - you'll lose a few inches insde
starleen2
5th Teardrop Club
Postby kirkman » Fri Apr 11, 2008 7:12 am
I like the block Idea also. Don't cut in to your baby...She could bleed out!
kirkman
Images: 55
Postby bobhenry » Fri Apr 11, 2008 7:28 am
I wanted the trailer deck as low as possible so
I chose to let the wheels and stockfenders on the HF
axle protrude thru the floor.
I was going to be content to leave the little 2 1/4" humps
under the mattress. Mid build I changed my mind.
I left the 1 1/2" 2x2 curb and added 2 layers of 3/4
foam covering the entire floor then sheeted over with
7/16 osb. Rattle can truckbed liner was applied to
weatherproof the underside. We never missed the
2 inchs and benefitted by gaining a well insulated floor.
Came in real handy in January at -1 F.
Postby Miriam C. » Sat Apr 12, 2008 6:17 am
Thank You all of you! I guess I will order my springs and make a plan. :? This should keep me busy for a month or two. :oops:
