Pop up camper frame
Pop up camper frame
Postby mechmagcn » Tue May 06, 2008 6:49 pm
Has anyone here used an old pop up frame when building a teardrop? I have a frame from a Starcraft popup that I have cut down to 5 X 10 that I will build on.
Here's a pic of my foundation,
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby daveleb55 » Wed May 07, 2008 12:10 am
We also started with a pop-up but did not take it down to the frame. Check our album for ideas. We are at the camp-able stage with just the fine tuning.
Dave & Kathleen
"Get off the #@$% computer and GO CAMPING!"
daveleb55
Images: 203
Postby Gage » Wed May 07, 2008 12:39 am
Nice Kathleen. Looks like someone got off the computer. :lol: Does that also mean you guys will be at Table Mountain next month and are you signed up for the IRG? :thinking: Must have all kinds of room in that sucker. :thumbsup:
Image Image Image
Gage
Images: 28
Postby mechmagcn » Wed May 07, 2008 6:37 am
Gage, I like the effie in your signature line, is this your tow vehicle? I plan to pull my TD with a Mercedes diesel powered 53 F100.
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby packerz4 » Wed May 07, 2008 6:40 am
yep, mine is built on one. (small trailer not a teardrop)
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby mechmagcn » Wed May 07, 2008 6:42 am
daveleb55, that is some nice work :applause: . The popup that my frame came from was way too far gone for me to try and save, I think it had been set up and forgot for years, so the water damage ws severe.
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby 2old2tent » Wed May 07, 2008 8:43 am
Check out Michele's Powder Puffin. http://tnttt.com/viewtopic.php?t=21785
Not a teardrop but it is on a Starcraft pop-up.
Here's mine.
http://tnttt.com/viewto ... highlight=
Again not a teardrop, but does use a Starcraft frame.
Jack
2old2tent
Images: 41
Postby Michele » Wed May 07, 2008 11:11 am
Yep, like Jack said, mine is a 1979 Starcraft. Lots of pictures here
http://picasaweb.google.com/4cupid/Trai ... ect1227111
and here
http://picasaweb.google.com/4cupid/TrailerProject112
Michele
Images: 120
Is there ever enough room?
Postby daveleb55 » Wed May 07, 2008 11:29 am
Heh heh,
Kathleen insisted that the one design criteria was being able to fit a queen size bed in it. It does fit, barely, crossways, as the width is around 6 1/2 feet. There are a few feet of space between the bed and the front wall to put a couple chairs. The Bed is inflatable, and has a section that lifts up to make additional seating. When finished (whenever that may be!) can seat 4 people comfortably around a small table.
Floor to ceiling height is 4 1/2 feet, not enough to stand up, but you can sit comfortable and put your pants on without being a contortionist.
I've started the hatch lighting and wiring for the interior. Next projects are to insulate and put in a roof vent or two.
Nah, we aren't going to table Mountain or the IRG this year, too many other things going on, and a lack of fundage is putting a crimp in our plans as well. There is a gathering at Calico in October we plan to go to, and also "Beatty Days", as well as Carson city in June. Trying to stay close to home this year.
Dave & Kathleen
Gage wrote:Image
daveleb55
Images: 203
Postby Miriam C. » Thu May 08, 2008 8:05 am
Jeff, ours is built on an old pop up that my brother had already stripped. We love it. Nothing like rolling over to make the coffee. 8)
A part of me wishes I hadn't raised it and had put the bed over the wheels. It sits pretty high. If I had to do it over the door would be up front and the bed in back.
Postby Tornadoboy » Thu May 08, 2008 9:40 am
Yep, I'm using a stripped 1951 Bethany Chief frame
Tornadoboy
Postby joestrom » Thu May 08, 2008 9:51 am
Take a look at Andrew/Grant's Campster 12 design. I've got a pop up trailer frame that appears to be ideal for that design. I've had intentions of doing the Glen-L Sequoia on it, but couldn't get enthused enough to actually start. The Campster design has got me going again tho!
Regards,
Joe
Joe Stromski
joestrom
Images: 5
Postby angib » Thu May 08, 2008 11:12 am
A while ago I did a modification of the Widget to fit on a pop-up frame
This frame was 93.5" long x 76" wide, but the design could be adapted to anything similar. There's a Widget in my Hall of Fame with a similar layout: Ron's Widget.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Bronco302 » Fri May 09, 2008 11:08 am
I wish I had taken photos of my Wheel Camp frame before I started on it but it looked just like this http://tnttt.com/viewto ... c&start=15 and was the same size(bottom photo) I cut it down to 5x8 and redid the tounge. Take a look in my album at what I ended up with. I needed a wider axle so I got one from Northern Tool. Enjoy.
Joe W.
Bronco302
Images: 11
