side table
side table
Postby pauld3 » Thu May 29, 2008 11:41 am
ok I searched and could not find an answer so..... I want to build a side table for our trailer, where or what kind of a bracket do you use to atach to side
thanks Paul
Paul & Lynn Donovan
The Toad Drop Inn
Liberal, KS
pauld3
Images: 94
Postby madjack » Thu May 29, 2008 12:00 pm
Paul, this what we used... http://www.tjtrailers.com/store/table-support.html ...there are other types out there as well...we cut this bracket into 3 10" pieces and placed it 3 different places on the trailer, we built two tables 16x30 ins and this gave us options on where to place the 2 tables...further, we ripped a 1/2" of of the long leg of the bracket so it wouldn't protrude as far...I liked it and will use it again......
madjack 8)
p.s. an adjustable paint roller pole makes and excellent outer leg for the table......MJ
Postby razorback » Thu May 29, 2008 1:53 pm
I think this may be the same style as MJ's link or very similiar.
Just about half the price.
http://www.tweetys.com/index.asp?PageAc ... odID=15554
Larry
razorback
Postby MrBuzz » Thu May 29, 2008 2:27 pm
For the side table on my TD I made my own brackets
To start with I fastened a piece of 3/4" aluminum angle to the bottom of the table.
And for the bracket on the side of the trailer I used a piece of laminate flooring that I cut, shaped and painted to make what looks like a decorative body-side molding when the table is not attached.
I fastened the new molding to the side of the trailer with scews and put 2-3 washer's between the molding and the body to leave a nice snug space for the aluminum angle on the bottom of the table to slide into.
Generic Benroy - built 2007, 4X8, 1175 HF trailer, Structoglass roof and headliner, 12v and 110v electrics with Schumacher charger.
MrBuzz
Images: 77
