Fenders to big, how can I...
Postby benzu » Mon Jun 02, 2008 1:04 pm
My fender are too big for my wheels, I know I have to cut them down and will probably do it with a jig saw but does any one else have any other ideas. I'm going to cut the back side flange off, no worries though I'm not attaching the fender that way I'm attaching them to 1" square tube that will be attached to the chasiss frame.
Thanks, Mike
benzu
Images: 119
Postby cuyeda » Mon Jun 02, 2008 1:58 pm
What material are those fenders made of? Doug H. narrowed his fiberglass fenders down.
http://www.tnttt.com/viewtopic.php?t=22356&highlight=
You could probably use the same steps using a metal cut off, and welding it back again. A bit more grinding, and a little bondo may smooth the surface out. When the paint is applied, it should hardly be noticeable.
Cliff & Vanessa
cuyeda
Postby benzu » Mon Jun 02, 2008 2:45 pm
http://tnttt.com/viewto ... highlight=
They are 16g steel, and I've seen that post of Doug H. but thanks anyways. Yeah I was thinking the same way a lot of welding sanding and bondo, I wonder if I can purchase new ones that are more custom fit to my trailer?
Thanks for your help.
Mike
benzu
Images: 119
Postby JIML1943 » Mon Jun 02, 2008 2:59 pm
How about just raising them up so you have the same clearance at the top as you do in the front and back may help the looks.
Some days all you can do is smile and wait for some kind soul to come along and pull your ass out the bind you've gotten yourself into.
Happy camping Jim & Barbara
JIML1943
Images: 71
Postby toypusher » Mon Jun 02, 2008 3:12 pm
JIML1943 wrote:How about just raising them up so you have the same clearance at the top as you do in the front and back may help the looks.
I was thinking more that maybe if you cut the front and back sections that hang below the frame, that they might look just fine without making them narrower.
toypusher
Images: 324
Postby benzu » Mon Jun 02, 2008 4:11 pm
That would be a lot easier then I wouldn't have to do any welding or bondo work.
Thanks, Larry
Mike
benzu
Images: 119
Postby Ivar the Red » Mon Jun 02, 2008 5:42 pm
Thanks, Larry
Mike
Just cut the front side and viola...instant mud flaps on the back. And even less welding or bondo work. :thinking:
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby john » Mon Jun 02, 2008 8:36 pm
Or just cut enough off with one cut so there are no long ends on the front or rear. The fender is round right?? Rotate the fender if it is round.
Also for aesthetic reasons I would try to keep the gap between tire and fender the same on the top and sides. If the gap is too large taller tires and/or larger wheels will fill the fender.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby jdarkoregon » Tue Jun 03, 2008 1:00 am
My thoughts were to bite the bullet and buy some the correct size for your tires, save what you have for another build.
By thinking new, you have all the options again
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby Esteban » Tue Jun 03, 2008 1:11 am
It might be cheaper, and much less fuss, to buy new fenders that fit better. If you consider buying new ones kmtparts.com has steel fenders at reasonable prices to fit a range of tires sizes and widths.
I bought 10-3/4" wide steels fenders for 14" wheels from them for $16 each. Some other sizes cost less. Their service was good and they arrived quickly. They look good and sturdy. I felt they were a very good buy when similar looking fiberglass fenders would have cost $250, or more, for a pair.
Steve - SLO, CA
Esteban
Images: 15
Postby Darren » Tue Jun 03, 2008 1:33 pm
Mike, I say make your own fenders. Your tear is beautiful and matching fenders would really make it stand out. In my opinion.
Here's a photo of my fenders, very easy to make.
Darren
the camper formerly known as Victor Star
Images: 161
Postby benzu » Tue Jun 03, 2008 1:36 pm
Victor, thanks for the advise I may do that later when I have time but for now I need fenders by next week.
Mike
benzu
Images: 119
