Fantastic fan gasket use
Postby shoeman » Fri Aug 08, 2008 8:38 am
I screwed my fan-tastic fan in place last night, using the supplied foam gasket. I really don't care for how it looks though.
Anybody here just gooped their fan directly to the roof, aluminum in my case?
Geoff
99% of the way done with a Generic Benroy. Only because these might never be done if you like to tinker. But it's on the road!
shoeman
Images: 22
Postby Arne » Fri Aug 08, 2008 8:49 am
I used the foam gasket. I put the screws in part way, then applied a dab of caulk to the barrel of each screw and set them in.. being sure that some caulk squeezed out from each screw so I knew it was sealed.
The I applied a thin bead of caulk around the perimeter of the foam gasket.
When I tightened the screws, I was careful not to deform the flange on the fan. There are so many screws they do not have to squeeze the gasket that much or that tightly.
It made a very neat installation.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby halfdome, Danny » Fri Aug 08, 2008 8:55 am
I did exactly like Arne did but I used stainless screws not the white ones supplied with the fan. I did that on both TD's and have had no problems. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby shoeman » Fri Aug 08, 2008 9:47 am
That flange is really soft and does distort a bit under each screw. If I back them off it straightens out, but the gasket is so thick the fan stands quite proud of the roof. I was thinking that if I silicone the daylights out of the flange and omit the gasket it will sit dead flat against the skin.
But of course the bottom line is no leaks.
shoeman
Images: 22
Postby Mary K » Fri Aug 08, 2008 10:21 am
I used the foam gasket and then sealed around it with caulking. It was designed to be installed with the fan so I used it. Many others have as well. Better safe than sorry. :thumbsup:
Also, I put caulking in the screw holes and over the top of them.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby madjack » Fri Aug 08, 2008 12:28 pm
shoe, we didn't use the gasket...placed vent in position...anchored two corners and predrilled all the screw holes...used SS screws...used auto windshield adhesive/sealer...put a heavy bead on each side of flange...placed vent in position and squirted some sealer in the screw holes...fastened it down and it is good to go.......
madjack 8)
Postby mechmagcn » Fri Aug 08, 2008 5:25 pm
madjack wrote:shoe, we didn't use the gasket...placed vent in position...anchored two corners and predrilled all the screw holes...used SS screws...used auto windshield adhesive/sealer...put a heavy bead on each side of flange...placed vent in position and squirted some sealer in the screw holes...fastened it down and it is good to go.......
madjack 8)
MJ, with an installation like that, I wouldn't even think you would need to use screws :o
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby mikeschn » Fri Aug 08, 2008 6:51 pm
Lexel would do it too! Just don't plan on taking it off.
