Cliffmeister2000 wrote:I made mine with a 3/4" frame, 1/4" skin on the outside, 1/8" skin on the inside. I am certain that a 1/8" skin on both sides would have been adequate. That's how they build luan hollow core doors for houses.
stomperxj wrote:I am limited to 1" thick doors...
Toytaco2 wrote:Ditto for me and filled the voids with 3/4" pink foam insulation. I plan to hang them this weekend.
Juneaudave wrote:Jess...most builders use the same construction on the doors that they did on the walls..that way the doors are the same thickness.
planovet wrote:
One question. Doesn't the doors need to be slightly narrower to account for the door seal?
Cliffmeister2000 wrote:I put an internal frame around my doors, allowing at least 3/4" overlap. I did not allow for a seal. Now, I am going to remove the frame, build a second frame out of 1/4" luan that has the inside dimension equal to the doorway, and sandwich it between the frame and the doorway. this will allow for the seal that I neglected originally.
planovet wrote:
That's what I was thinking of doing. I have built an inside frame similar to yours but I have not installed it yet. I figure your way would be easier than trying to build a narrower door.
planovet wrote:That's an interesting way to do it but I like my (and your) wood choice better.
One more question. Do you do the seal all around the frame the same way? Does the hinge end of the door scrape it off?
