Asphalt emulsion?
Asphalt emulsion?
Postby jimslack » Fri Jul 29, 2005 6:21 pm
I have just starting building a Cubby and am collecting materials. The plans say to coat the bottom with asphalt emulsion, but I can't find it anywhere. The people at my local Home Depot have no idea what it is. Any clues about where to get it?
Thanks.
jimslack
Postby mikeschn » Fri Jul 29, 2005 6:37 pm
Here's what I used...
http://www.mikenchell.com/live/01_04_20 ... ive43.html
You can see the rest of my build journal here...
http://www.mikenchell.com/live/index.html
Postby bledsoe3 » Fri Jul 29, 2005 6:38 pm
It's in with the roofing supplies. Only about $7 a can.
bledsoe3
Images: 112
Postby ALAN GEDDES » Fri Jul 29, 2005 6:41 pm
Go to HD and look in the roof patching area. Thats where I get mine. They sell it in 1 and 5 gallon cans. It's pouring down rain right now or I would go out and tell you what the brand name is.
Alan
ALAN GEDDES
Images: 34
Postby jimslack » Fri Jul 29, 2005 8:29 pm
I wondered if it was the same thing as roof patch, but the folks at HD said it wasn't. I picked up "White Elastomeric Roof Coating" -- will that work?
Thanks for the quick replies!!
jimslack
Postby exminnesotaboy » Fri Jul 29, 2005 8:37 pm
I used a product very similar to Mike above and I believe I got it at Home Depot for about 8$. Get a big, cheap paint brush(you will throw it when done). I found it *much* easier to use after leaving the can in the sun for a couple of hours before use. One coat did it, but it took several days to dry good.
oh, by the way, that stuff has a will of it's own and will jump on your clothes and never come off - be prepared :)
exminnesotaboy
Postby Ron Dickey » Fri Jul 29, 2005 10:43 pm
I got mine at Ace hardware. a qt for 2.99 I may need a 2nd one.
Ron D.
173882......173887
Ron Dickey
Images: 787
Postby bledsoe3 » Sat Jul 30, 2005 2:15 am
The brand I used was Henrys. I found it in the roofing section. It is black and about $8. Plan on throwing away your brush and wear gloves. I tried something different. I used a paint stir stick and spread across the plywood. It worked pretty good, but you have to be careful to spread it evenly. If you get it too thick, it will take days to dry.
bledsoe3
Images: 112
Postby IraRat » Sat Jul 30, 2005 8:54 am
It's not the white stuff. HD definitely has what you're looking for, though.
The can might not say "asphalt," don't remember. Maybe just roofing emulsion.
--Ira
IraRat
Forum Storyteller
Postby Chip » Sat Jul 30, 2005 9:22 am
The white elastomeric will work just fine, it just doesnt penetrate the wood as much as the asphalt coating,, the asphalt coating is under the brand name Henry, just dont get cement,, its too thick and harder to work with,, it should say something to the effect ,, roof coating or asphalt roof coating,,
wear old clothes though, the stuff will jump 5 feet to get on ya while ya putting it on
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby TomS » Sat Jul 30, 2005 2:18 pm
I used this stuff. I got it at in the roofing department at Lowe's
Tom Swenson
[email protected]
TomS
Postby Marck » Sat Jul 30, 2005 5:25 pm
Tom,
I just bought 5 gl of the same thing.
You want to build WHAT?????
40 isn't middle aged....
IT'S YOUTH PART II
Marck
Images: 64
Postby TomS » Sat Jul 30, 2005 5:29 pm
Marck wrote:Tom,
5 Gallons? Holey Moley! I only used about a third of that 1 gallon can to coat the underside of my 5x8 tear.
Tom Swenson
[email protected]
TomS
Postby IraRat » Sat Jul 30, 2005 7:10 pm
Yep--that's the stuff I bought...Gardner. And like Tom, with one gallon, I have enough left over to do all the other tears on the block.
I seem to recall it doesn't have a long shelf life, or maybe I'm thinking of something else.
And Tom, I'm really disappointed with you! What a messy job you must have done, what with that stuff dripping down the side of the can like that!
Actually, on mine, you can't even read the label now--and there's no green visible at all.
--Ira
IraRat
Forum Storyteller
Postby Marck » Sat Jul 30, 2005 7:18 pm
5 gllon = got to build more T&TTT
8)
building #2 already a modernistic
next will be a kuffle creek cubby
:D :) :lol: :twisted: :thumbsup: :applause: :thinking: :lol: 8) :) :D
IT'S YOUTH PART II
Marck
Images: 64
