Kenny,
The more robust axle actually has no effect on shock loads as the rubber rating inside or the spring ratings determine shock absorption. Thus, an axle rated at 3500 lbs. won't make your ride any more stiff, by itself. The heavier axle, (which has the penalty of extra weight, as you note) is simply stronger, which is crucial. The weight of the wheels doesn't even pertain to axle loading (since it is unsprung weight) but is important to axle integrity. I don't want to snap an axle. In my case, you have to think of the overhang as the distance from a pivot point (where the axle is attached to the frame) or fulcrum. The entire wheel becomes a weight that is suspended from that fulcrum and acts like a lever, so that the increased force of that weight is actually the square of the increased distance from the pivot point. Since my wheel is about 40% farther away than recommended, the force on the end will be many times greater. At least that is the way I understand it.
madjack wrote:... static load is the point to what I was saying about ratings...if you have a trailer with a 1k load rating and you have 1k worth of weight on that axle at all times (static load), the axle is at it's maximum recommended deflection at all times...
madjack wrote:...this puts constant stresses on the springs and will thus weaken the springs over time(ask any metallurgist)...
madjack wrote:Bryan, static load is the point to what I was saying about ratings...if you have a trailer with a 1k load rating and you have 1k worth of weight on that axle at all times (static load), the axle is at it's maximum recommended deflection at all times...this puts constant stresses on the springs and will thus weaken the springs over time(ask any metallurgist)...now, hammer down the Intestate for an extended trip with that spring which is fully loaded to begin and you end up with a situation in which the spring can literally beat it's self to death, because the "G"force loadings are ALWAYS over the max recommendations(mass and momentum...thank you Mr Wizard)...seen it happen WAYYYY too many times...this is the reason many older campers you see, seem to be "squatting" or are in need or spring replacement(read vintage trailer forums about this common problem)...I find it very disingenuous of you to at one time knock a manufacturers recommendations(ProMariner) and at the same time use manufacturers guidelines to post info...the info I have posted comes not from a book or reading tech manuals but from hard won experience in the trailering industry and not just the heavy 18wheelers but trailers of all types and sizes.........
