I'm considering routering a grove in the faceplate for the cabinet walls and the floor of the top cabinet. I'm using 1/4 oak plywood for the walls and floor.
Is this the best approach? What other options would work?
RichAFix wrote:Pocket screws. Strong, cheap, easy. I rarely use my biscuit jointer anymore. Don't get me wrong, biscuits are easy, but if you have parallel biscuits it is a little bit of a hassle. You can't miss with pocket screws, and once you have the jig you will use it for everything.
