Propane Tent Heater
Postby brian_bp » Mon Feb 16, 2009 2:46 pm
xrover wrote:...The guidelines say you need 1 watt per cubic ft of space to maintain room temperature (this is a loose interpretation of building codes). For a 4x8 tears, that works out to less than 100 watts...
The problem is that heat requirement is all about the surfaces of the space, not the volume. It would make more sense to say how many watts are needed per square foot of walls, roof, and floor.
The residential guideline assumes that the space is of normal house proportions, but a trailer is much smaller and thus has much more area losing heat per cubic foot of interior. They also assume normal residential insulation levels, while trailers have much less insulation. Finally, houses sit on (or into) the ground, while trailers have a bottom exposed to the cold air.
The other problem is that the heat input which is required obviously depends on the outside temperature.
For a marginally insulated teardrop in sub-freezing temperatures, 100 W doesn't sound like nearly enough, although there is the contribution of body heat!
An important point here is that the electric heat requirement assumes a nearly continuous source, instead of the blast-and-shutdown approach of the portable propane heaters. If a heat source can be run continuously, I agree that it can be pretty small. A tiny (physically, and in heat output) propane furnace which is safe to run continuously would be nice.
brian_bp
Images: 9
Postby wlooper89 » Thu May 14, 2009 2:04 am
A teardrop stays pretty warm just from body heat I have found if the temps are not much below freezing, but now we take our cat camping and leave a trailer door open so she can hop in and out of the trailer into the attached screen room tent. This way she can get to her food, water and litter box. But leaving the trailer door open makes a big difference on cold nights. A recent addition is an electric blanket to fit the trailer. I plan to try it out this weekend at the Misty River Rally in TN. The weather will be warm, low 60's at night, but we can use it if needed. When we take the cat we will try to stay where there is electric connection on cold nights.
Bill
wlooper89
Images: 75
Postby kennyrayandersen » Thu May 14, 2009 7:40 am
Though technically you are correct with regard to the heat transfer, since most of the trailers fal within pretty close size parameters a volume factor probably wouldn't bee off by so much.
Basically you are talking about a big dog house here :lol: A 300 watt bulb (or equivalent power) would heat the inside. We keep dogs and plenty of other farm animals warm all winter long with light bulbs. A SMALL electric heater heater as several have posted would be plenty to keep a 8-10 ft. tear warm -- esp. if it is insulated .75-1 inch in the walls -- many also have 2 inch thick foam in the floors -- our dogs never had it that good!
:lol:
kennyrayandersen
Images: 38
