Best Side Table Surface Material
Postby Dean_A » Fri May 22, 2009 6:16 pm
Well, I finished the trailer, but now it's time to move on to the "improvements".
I'm going to build a side table to give me a little more counter space when working in the galley, and I want to know the best surface material.
I have left over aluminum, left over Formica, and left over birch plywood. I'm also open to other suggestions. I want something that will hold up OK to sunlight, and the occasional bit of unexpected rain.
My preference is to use the Formica, as it looks great and would match the galley, but I've had no luck online finding any info about using it outdoors.
Thanks!
--Dean
Dean_A
Images: 55
Postby caseydog » Fri May 22, 2009 6:24 pm
I used birch plywood with a clear polyurethane. But that was also my galley top finish.
I would probably use the same formica that you used on your galley top. It will hold up fine as long as it is not in the weather all the time. For the amount of time you go camping, I can't see the sun damaging it, and the occasional rain should be okay, as long as you don't leave it in the rain all day. That's true of any surface, for the most part.
I vote for the formica. :thumbsup:
BTW, you can always put a UV protecting coating for vinyl on the formica for extra protection. A car care product with UV protection would do the trick.
CD
My build journal is HERE
caseydog
Images: 515
Postby Lou Park » Fri May 22, 2009 6:42 pm
How about you do one side in formica and the other in aluminum so
if you get tired of seeing one, you flip it over to see the other.
Lou
Lou Park
Images: 5
Postby Miriam C. » Fri May 22, 2009 6:49 pm
Can you seal the aluminum so it doesn't stain. I wish I could do a stainless side table.
If you have left over material then you can make more than one. Put one back for later........... :twisted:
Postby Dean_A » Fri May 22, 2009 6:59 pm
Miriam C. wrote:Can you seal the aluminum so it doesn't stain. I wish I could do a stainless side table.
I'm using a wipe on clear coat that *should* protect the aluminum from any sort or staining or oxidation.
The trailer took me 4.5 years. I don't work fast enough to make extra ANYTHING. :lol:
Dean_A
Images: 55
Postby Mike Angeles » Sat May 23, 2009 5:17 am
Dean,
I just completed mine, I used formica to match the Galey, Aluminum would look sharp though.
Mike
tact /takt/ –noun
1. a keen sense of what to say or do to avoid giving offense; including the ability to speak or act without offending.
2. a keen sense of what is appropriate, tasteful, or aesthetically pleasing; taste;
Mike Angeles
Images: 76
Postby Rock » Sat May 23, 2009 6:47 am
How about a thin sheet of stainless steel over a thicker piece of plain steel - then it's a dutch oven table as well?
That's what I'm doing but it will pretty much be a dedicated DO table, not necessarily for extra counter space.
Eric
Rock
Images: 48
Postby Dagny » Sat May 23, 2009 8:16 am
Mike, did you buy a hardware kit to attach it? or make it yourself. I'm loking to add one too.
Dagny
Postby Mike Angeles » Sat May 23, 2009 9:16 am
Hey Dagny I did make it. I got the idea from Doug Hodder. Table can be moved to either side of the Galley. I needed a place to fit the stove since I ran out of room in the galley for a pull out. I have a few more pics in my Album as well.
Thanks,
Mike
tact /takt/ –noun
Mike Angeles
Images: 76
Re: Best Side Table Surface Material
Postby planovet » Sat May 23, 2009 9:41 am
Dean_A wrote:My preference is to use the Formica, as it looks great and would match the galley, but I've had no luck online finding any info about using it outdoors.
I vote for Formica. As for using it outdoors, Eddie built the Evac A Shack and covered the whole thing with Formica. It's faded a little but has held up well.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Dean_A » Sat May 23, 2009 11:04 am
Thanks everybody. Formica it is!
Dean_A
Images: 55
Users browsing this forum: Bing [Bot] and 6 guests
