how to make an awning?
Postby sqweaka » Fri Jul 03, 2009 11:18 am
Anyone got any good ideas on how to go about making an awning that can attach to the side of a teardrop?
Looking for ideas to make my own, simpler the better but don’t want to use a modern tent/type or gazebo type shelter
sqweaka
Postby Juneaudave » Fri Jul 03, 2009 11:30 am
Well...you might start by thinking about how you might use awning rail and welt to attach it to the trailer. I think there are quite a few suppliers out there...Awning Rail
Juneaudave
Images: 380
Postby len19070 » Fri Jul 03, 2009 5:41 pm
I've built quite a few.
Very simple
1 length of 2" or so thin wall pipe (only as long as the awning is needed) Aluminum if possible
A bag of pop rivets
A length of awning rail
4 adjustable tent poles from Wally World
_________________________________________________________
Mount the awning rail to the side of the coach and to the 2" or so thin wall pipe.
The thin wall pipe should be 4" longer than your awning fabric.
At the end of the 2" pipe drill 2 3/8" holes straight through, holes should be at 1, 3, 6 & 9 o'clock making the awning rail at 9 o'clock. Your uprights and out lookers will fit into these.
Your uprights and out looker rods are the Wally world poles.
As for the fabric, if you have an RV dealer around see if he has any wrecked awnings that you could have the fabric from. They will probably give this to you (I know I do)
If NOT
Select the fabric you want, sew the ends then sew 2 lengths of wire or cloths line into the fabric by simply overlapping the fabric over the wire.
MAKE SURE the wire and the fabric will fit through the awning rail.
Insert the fabric into the outer tube then slide the other end into the rail on the coach.
Extend the fabric and outer tube then insert 2 Wally world tubes into the vertical holes on the outer tube.
Then insert the other 2 poles into the horizontal holes, extend them and put the but ends onto the awning rail on the coach. These poles must be tight!
Note; The poles should have plastic bumpers on them. You may want to replace them with rubber,
Happy Trails
Len
len19070
Images: 24
Postby mallymal » Fri Jul 03, 2009 5:46 pm
Or you could buy this for £29....
http://www.campingandleisure.co.uk/catalog/product_info.php?cPath=3_127&products_id=1738&osCsid=e9f9f3990ff96fbe90e211f06bf7fe67
Can't see how it fixes on, but I'm sure at that price you'd have more than enough bits & pieces for less than the cost of buying all the components ;)
mallymal
Images: 18
Postby WesGrimes » Fri Jul 03, 2009 6:02 pm
I was thinking of attaching snaps every 6" or so on top of the trailer, installing a couple of marine flag pole mounts that are 45 degree angled at the base of the trailer pointing up and using aluminum adjustable tent poles to extend to the awning. Haven't built it though, so just a thought...
WesGrimes
Images: 31
Postby kevin57 » Fri Jul 03, 2009 6:40 pm
I posted my awning under 5 dollar awning in the cargo conversion section, it might give you some ideas.
Kevin
happy wife = happy life
kevin57
Images: 70
