mikeschn wrote:If I were building something that I wanted to put 1/2" insulation in the walls, baltic birch would be just the thing!!!
Jst83 wrote:mikeschn wrote:If I were building something that I wanted to put 1/2" insulation in the walls, baltic birch would be just the thing!!!
Question that has to do with side so I guess it's not a total hijack. If you go with the 1/2" plywood and wanted to inlay insulation what would you do cause it's not 1/2" thick. Did that make since?
toypusher wrote:The foil bubble foil stuff that you can get at HD and Lowes??
