Sidewall Thickness
Sidewall Thickness
Postby Adz_4 » Thu Oct 01, 2009 3:42 pm
My teardrop is going to have single skin sidewalls and I don't know whether to use 1/2 inch plywood or 3/4 plywood. I would rather use 1/2" but are there any reasons why I should opt for using the thicker stuff? is 1/2" sufficiently rigid for the sidewalls?
See the progress of my Teardrop project here: www.teardroptrailer.tk
Adz_4
Postby mikeschn » Thu Oct 01, 2009 3:49 pm
1/2" is plenty. I used 1/2" on my Giant TD (in the HOF). Why add the extra weight if you don't need it.
Postby doctor phreak » Thu Oct 01, 2009 4:42 pm
i am doing 1/2" wall with a 3/4" core and then another 1/2" ply on the inside so my total wall thickness is going to 1-3/4" thick..some may say this is too heavy but for me weight really isnt a issue with my TV.....
doctor phreak
Postby jackdaw » Thu Oct 01, 2009 6:31 pm
If you don't need to insulate , I'm with Mike 1/2" is good. :thumbsup:
We used 3/4" on the Grumman, and the 1/2" on the Coppertop.
The copper top has turned out so much lighter than the grumman, I know it's a fair bit smaller, and less comprehensive, but I'm sure the thinner sides have helped. We used 1/4" for the floor on a 1 1/2 stud frame. With the mattress on top, we haven't noticed any lack of performance either.
#3 will have 1/2" sides. :thumbsup:
Dave
jackdaw
Images: 124
Postby Ken » Thu Oct 01, 2009 10:01 pm
haven's posted in years, sorry. This is what I did and it has lasted 40,000 miles plus with no problems or even thought of problems, I an sure it will last another 40. I am really quite surprised how strong it turned out. Start with ½ inch exterior (according the park rangers it keeps the bears out, trust me, it worked). Use ¾ spacers like studs in homes, fill that with ¾ inch styrofoam, glue everything, glue the spacer to the exterior and interior skins, glue the styrofoam to both sides of the walls. Finish the interior with 1/8 luan. Glue this to the styrophome and the ¾ inch spacers. The combination is strong as steal and insulated like an igloo ice box. Coldest nite so far was 18 absolutely toasty inside.
Ken
Keeper of the Green Key
Users browsing this forum: IndigoIrish and 11 guests
