I was about to build my sandwich walls but stopped, feeling a bit unsure about how I was going to trim out the lower portion of the wall. This is my current idea:
At first, I was going to run the wall and aluminum skin down to be flush with the bottom of the frame, but realized that affixing the trim could be an issue as there will be minimal screwing/riveting surface available. Does anyone forsee issues with running the sking to 1/2" or so below the frame and riveting as shown?
Opinions one way or the other are appreciated. Not being the most effective searcher on here, links to similar designs or alternatives are welcomed.
Thanks
Brian
