daddiozz wrote:I got all my fittings at LOEWS...I"m not 100% sure what you are refering to....if its the piece I'm thinking of ..it has 2 slipjoint ends and one threaded(Female),.....just get yourself a threaded coupling (male) of the same size which has the slip joint on the opposite end and you should be in business...
DonK wrote:Daddiozz,
I'm very interested in your trailer. I've been exploring options for a very light trailer. I have a few questions:
What is the material you're using for the new sides? What thickness? Can you post a link to it?
How did you shim between the pipe and the wall? Is it needed with the new walls? Are the new walls rigid enough to attach only at the joints?
Have you made the doors and hatch watertight? How did you attach them to the frame?
Thanks for the great work you've done. It's really impressive.
Don
moreforles wrote:The boards I was referring to was about 1/4 to 1/2" thick, by 2' width and 5 or 6' long, a home remodeler was using it to make recessed basement window surrounds, figured if it was good enough to put in the ground, a little rain or snow shouldn't hurt it....
He told me it was solid pvc, and he also used 1x4 and 1x6 pvc board for trim too... I wonder if it could be used in place of lumber.....(naw, need something fo screws to bite and hold to for hinges and such)
moreforles wrote:. I wonder if it could be used in place of lumber.....(naw, need something fo screws to bite and hold to for hinges and such)
