Customizing A Winter Warrior/ 01/09/2010 Got a profile!
Postby starleen2 » Sat Jan 09, 2010 8:59 pm
rxc463 wrote:Can anyone suggest a spar size and spacing for that 80" span
:thinking:
Check out the Ladybug spacing - it's about the same width. The main spars are 1 3/4 X 3/4 inch thick. However the main hinge spars are a full 2X3 to prevent sagging at the hinge joint. I also added to the center spar on the front to make it a little thicker. Wslively and his WW is also a good candidate to look at for spar spacing
starleen2
5th Teardrop Club
