Hi I have looked into many adhesives on the internet to see what one is the best for glueing the sides ,the spars etc. and I wanted to get other builders views.
I was thinking about the LP subfloor and deck adhesive because you can use it to o degrees. I know it is fairly thick stuff and I wonder if that is a problem with the building of a tear drop.
If anyone has worked with this or knows of something better please let me know. My shop hovers around that 37 degree mark most of the time and carpenters glue you need above 50.
Thanks
