Here's a
link to a PDF file about the product. The EasyPoxy is a one part polyeurethane enamel paint. Their thinning instructions for spraying is to ure more thinner than I would for regular poly finishes. It comes in white and 25 colors.
Their
web site lists several types of paint (epoxy, oil and poly enamels) and many different primers for different top coats and applications. They also have fillers and sealers. I'd think that an auto filler like Bondo would work as well as their epoxy filler and would be cheaper to use. They recommend a coat of sealer, two coats of primer, and then the top coats of EasyPoxy
Another website stated that a gallon of EasyPoxy covers 600 sq. ft. If that is the case, one gallon would do two coats sprayed on my TTT as It should have about 250 ftsq of surface area. From what I read, two coats would be enough. Prices found online run from $70 to $80 per gallon or $25 to $28 per quart. West Marine, however charges a lot more. It was $99.99 per gallon and $31.99 per quart from West.
Bottom line, is it worth the extra money? I'm not sure I want to pay nearly $300 just to paint. I think a good wood sealer and primer followed with a couple of coats of a good quality poly paint with UV inhibitors would work for a lot less money.
