Here I am layout trailer 3 in the auxiliary shop.
Larry C wrote:If the image opens full size,(I am still trying to get this picture thing right) it will show the batten method.
I drew the x y points on a 4x8 sheet of 1/8 Masonite using a tape measure and a drywall square. A small finish nail was driven into the Masonite and the OSB table top below, at each point. A 1/2" wide x 1/16" wood batten was clamped to each finish nail with miny clamps and small binder clips. Looking straight down on the batten, your eye can detect the tiniest out of fair curve. bend a nail to correct or move the nail if necesary. The batten is clamped to the nails about every 3", so it's quite rigid. Draw a pencil line along the batten, It's now a perfect fair curve profile to use as a pattern.
Cut close to the line with a jig saw and finish with a block plane and sanding block. This method worked well for me. It's a simple process that takes little time to get perfect results.
Larry C
LDK wrote:On making the pattern of my teardrop would it be better to draw it on cardboard or a cheap piece of 4x8 wood???<Or should I just draw it on the original plywood?
