How Much (If Any) Overlap at Bottom of Hatch?
Postby John6012 » Mon Dec 26, 2005 7:24 pm
I've built the hatch, it's not skinned but screwed on as a dry fit. My question is, how much overlap at the bottom where it meets the rear floor? I cut it flush with the floor but after studying the situation, feel an overlap is needed for a good seal. If I have to, I can rip off the luan and glue another piece on with an overlap and I've got it. Or, I can glue a second sheet of luan making 1/2 inch which adds much to the weight...Probably the best thing is to start over keeping the weight to a minum huh? Thanks
John6012
Postby TomS » Mon Dec 26, 2005 7:46 pm
No need to rebuild that hatch. Simply screw a 1/8 x 1 1/2" strip of aluminum to the bottom of your hatch. Not only will you cover that gap, you will also have a nice drip edge to divert water away from your galley floor.
As you can see, I had to relieve mine a bit to accomodate the hatch handle. Be sure to use plenty of caulk. Finally, I put a thick weather strip right up against the drip edge along the botom of the hatch.
Tom Swenson
[email protected]
TomS
Postby bdosborn » Mon Dec 26, 2005 8:40 pm
I did the same thing only I used t-molding instead of a flat strip.
Images: 806
Postby John6012 » Tue Dec 27, 2005 9:26 am
Thanks for he quick replies. I will go with your idea of an aluminum strip. It will bemuch, much esier than my final idea last night of cutting about 6 inches off the bottom of the hatch and putting another piece of luan on. Many thanks!
John6012
Postby doug hodder » Tue Dec 27, 2005 10:40 am
Like Tom mentions....I used a strip of aluminum in that area...but I did leave some ply behind it when I built it....a rod locking system like on a truck topper will allow you to place the handle further up the hatch, so you won't have to relieve the area where the handle and the aluminum strip meet....Doug
Postby John6012 » Tue Dec 27, 2005 5:25 pm
TomS, is that a 1/2" strip overhang on your hatch? Thanks, John
John6012
Postby TomS » Tue Dec 27, 2005 8:22 pm
John6012 wrote:TomS, is that a 1/2" strip overhang on your hatch? Thanks, John
The aluminum strip is 1 1/2 inches wide. I have 1/2 inch on the hatch, just enough to hold the screws. The remaining width, about an inch extends beyond the end of the hatch.
Tom Swenson
[email protected]
TomS
Postby John6012 » Tue Dec 27, 2005 9:52 pm
Thanks Tom for the reply. I'll use your idea on the hatch. Regards, John
John6012
