Sandwich wall: building it "in place" or separatel
Postby zapj » Sun Aug 15, 2010 12:00 am
I built my frame on the workshop floor then carried it to the assembly shed. You can see that the wall framing was bolted to the floor and frame then the skin was applied.
zapj
Images: 40
Postby Senior Ninja » Sun Aug 15, 2010 1:06 am
We built the walls on a sawhorse bench. We included all the wiring and insulation.
We left a keyway in the bottom of both walls and glued and screwed a key to the trailer floor. We stood up the walls and glued and stapled the walls to the key.
Building on the flat allowed us to use a minimum of fasteners, because we made it a woody.
A third method is illustrated by a man and his son who built their wall on the wall of a small building. A Los Angelos builder tried to hire them to build trailers using the "wall" method.
Building the TD was the best thing I ever made.
Senior Ninja
