Waterproofing under aluminum skin??
Postby LDK » Sat Aug 14, 2010 10:38 am
Should I waterproof the floor and sidewalls inside and out and if so what should I use? I'm gonna use aluminum for the outer skin. Thanks in advance.--------Larry
LDK
Postby GPW » Sat Aug 14, 2010 12:16 pm
LDK, waterproofing is never a bad idea !!! seal it ALL ... many products available ... What are you using for walls etc. ?
Postby LDK » Sat Aug 14, 2010 12:50 pm
I'm either gonna use 3/8" or 1/2" acx plywood. I may have to use 3/8" because I ended up making my floor framing 47-3/16" wide. I'm making a 4x8 trailer.
LDK
Postby GPW » Sat Aug 14, 2010 1:12 pm
Plywood :o ... Best waterproof as much as you can ... :thumbsup:
Not a bad idea to find some place covered to store it too !!! ;)
Postby starleen2 » Sat Aug 14, 2010 1:56 pm
I've used regular enamel latex paint under mine when I skinned over with aluminum. Had plenty just laying around - needing to be used - didn't really matter about the color 'caus I was covering it up anyways.
starleen2
5th Teardrop Club
Postby Cliffmeister2000 » Mon Aug 16, 2010 9:30 am
I used CPES. I love the stuff!
http://www.rotdoctor.com/products/cpes.html
I didn't use aluminum skin, but still needed to protect the plywood.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby len19070 » Mon Aug 16, 2010 9:44 am
Anything applied is better than nothing from Paint to CPES.
I use Thompsons Water Seal OR if I have any Varnish thats about to go bad (Thinned).
Looks don't mean a thing.
Happy Trails
Len.
len19070
Images: 24
