Rigsby wrote:As long as the sides are well glued and screwed to the base, you will find it stiffens up substantialy as you fix in the spars. And when you get the galley firewall in, you will wonder what you were worrying about
We have all wondered at what point the wobble will stop
steve
Miriam C. wrote: ................That will hold your walls up while you fix the spars................
Gage wrote:Miriam C. wrote: ................That will hold your walls up while you fix the spars................
Looks to me that his walls are up. Just need to add plywood.
What do you think, maybe some diagonal braces in the rear like has been done up front?
