Planned on using iron pipe; going from in front, underneath to the rear where the stove is -- about 13 feet or so.
What diameter pipe should be used? I was thinking there must be some kind of chart for this but couldn't find one.
Steve_Cox wrote:Used 3/8" copper tubing with compression fittings. Used a bulkhead fitting where it went through the trailer floor in the galley and LP hose to the stove. The copper tubing was inside a piece of 1/2" EMT under the trailer to protect it. I don't say this was the proper way, just my way.
Steve_Cox wrote:I also use one of those long propane lighters to leak test it when I turn on the gas.
