Thanks!
(See my gallery for pictures of the whole frame)
http://mikenchell.com/forums/album_personal.php?user_id=12156
Hello Dustin: I like the larger wheels and tires. That will make a difference in the ride of your Benroy. You can use those wheels but I would modify your frame and make the piece that goes in front of the wheels. The outside of the trailer. You can have a welder cut them out and make them so you can remove them from the frame if you need to change the wheel and tire. They would have to make a couple of extensions on the part that is cut out and make them so they bolt back on to the trailer frame. This will keep most of the stiffness that was designed in the frame as before and tire changes would be accessible. Just my thoughts on your dilemma.
Good luck on your build.
