relocating axle harbor freight 1800
Postby seahorse » Sun Feb 05, 2006 9:18 pm
Has anyone moved the axle back 4"or so, on a harbor freight 1800# trailer? any welding etc....... :thinking: Looking for suggestions. Thanks......Rob
seahorse
Images: 39
Postby toypusher » Sun Feb 05, 2006 9:20 pm
You should not have to weld anything. Just drill new holes to mount the brackets that the axle is mounted on.
toypusher
Images: 324
Postby seahorse » Sun Feb 05, 2006 9:28 pm
Thanks, My worry is the splice on the trailer, where the front rail meets the back. The axle angle looks like overlays this splice for support???????
seahorse
Images: 39
Postby toypusher » Sun Feb 05, 2006 9:43 pm
True, it does. You can take the two crossmembers at that joint and put them lengthwise inside the side rails to joint the two halves together and do away with the folding part. You then use a wooden crossmember to replace the two that you used. Check out the 'Generic Benroy Plans' at the top of the page. The trailer used in the plans is not the HF, but the principle is the same.
toypusher
Images: 324
Postby seahorse » Sun Feb 05, 2006 9:45 pm
Thanks Kerry, U DA MAN!........Rob :applause:
seahorse
Images: 39
Postby IndyCubby » Sun Feb 05, 2006 9:51 pm
Seahorse:
As I recall, the trailer is kind of built in two halves (according to the HF instructions) and then you are supposed to bolt them together in the middle. Most people here will take the two center cross members out and insert one on each side (inside the two side rails) and bolt them in so that the sides are stronger. If I remember correctly, I had to cut them down a bit to fit between the remaining cross members.
Then, you make your own center cross member either out of wood or angle iron to replace the two you used on the sides (I made mine out of angle and had my dad weld it in for me). Then you can mount your axle/spring assembly anywhere on the sides by drilling new holes.
Does that make any sense? :thinking:
4x8 Cubby
"Finished" October, 2005
Gone, but not forgotten!
IndyCubby
Images: 16
Postby IndyCubby » Sun Feb 05, 2006 9:53 pm
toypusher wrote:True, it does. You can take the two crossmembers at that joint and put them lengthwise inside the side rails to joint the two halves together and do away with the folding part. You then use a wooden crossmember to replace the two that you used. Check out the 'Generic Benroy Plans' at the top of the page. The trailer used in the plans is not the HF, but the principle is the same.
You beat me to it, Toypusher....and said it way more clearly than I did! :thumbsup:
4x8 Cubby
IndyCubby
Images: 16
Postby seahorse » Sun Feb 05, 2006 10:02 pm
Thanks Gentlemen, Same answer.........must be the way to go! :thumbsup:
seahorse
Images: 39
Postby Ira » Mon Feb 06, 2006 9:17 am
Seahorse, I did it exactly as described above, but you don't have to cut anything. Just drill new holes for the spring hangers in the new position--but be careful:
I set my axle 36" from the rear, and per the Cubby plans, first I inserted those cross members into the side channels instead of using them as cross members. I drilled my holes and bolted those mothers on. I'm living large now, right?
Wrong.
A few of those bolts now interfered with placing the spring hangers, so I had to remove and move them to a different position.
It was an unecessary extra pain.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby mikeschn » Mon Feb 06, 2006 6:15 pm
Seahorse,
How far is the center of your axle from the rear of the trailer?
Postby Ira » Tue Feb 07, 2006 8:53 am
Isn't the axle like dead center on all of these HF trailers?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby seahorse » Tue Feb 07, 2006 5:05 pm
42 inches
seahorse
Images: 39
