vapor barrier
vapor barrier
Postby Zeke » Mon May 09, 2011 9:04 pm
Okay guys - question?
After installing the insulation can I install a vapor barrier, then put the wood down?
Thanks,
Zeke
Zeke
Postby dh » Tue May 10, 2011 9:01 pm
How are you coating the outside? I would have a hard time seeing vapor getting through epoxy.
dh
Postby StandUpGuy » Tue May 10, 2011 9:10 pm
I do believe that rigid foam insulation is a vapor barrier.
I am making a shower unit so I will be doing a vapor barrier in the bathroom walls.
StandUpGuy
Images: 52
Re: vapor barrier
Postby StandUpGuy » Tue May 10, 2011 9:19 pm
Zeke wrote:Okay guys - question?
Thanks,
Zeke
The big problem for you there is that if you use a plastic vapor barrier you lose the wood on wood contact for glueing.
StandUpGuy
Images: 52
vapor
Postby 3822sean » Tue May 10, 2011 11:07 pm
have not heard anyone using it,i know in a house the wrong kind can cause more problems :thinking:
3822sean
Images: 37
Postby Artificer » Thu May 12, 2011 6:27 pm
I would have the frame with infilled foam (tight joints) and just fiberglass the inside. Strong, waterproof, and you can make whatever shape you wanted. You could even make a built in sink, if you wanted.
Michael
Artificer
Images: 16
