Pizzaguy wrote:I used NO stain on mine. Roof, front & back are oak. Sides are Cherry on top of birch. Trim is mahogany.
I was also under the assumption that you should only use an alkaline dye under epoxy as a oil or latex stain will not allow the epoxy to bond to the wood. I decided to not use dye after testing out the epoxy on test pieces.
aggie79 wrote:
aggie79 wrote:My tongue box was built from red cedar. I used TransTint dye to darken the wood to give it a little character and make it look like it was aged.
I waited about a month after dying the wood and then applied 3 coats of epoxy. About a month later, I applied 3 coats of Emtech EM9300 urethane.
aggie79 wrote:Once the water (or alcohol) evaporates you're good to go with epoxy.
